B BlvdKing Golden Member Jun 7, 2000 1,173 0 0 Jun 6, 2004 #1 What are the best setting for memtest? I have been running CPU cache off, all tests, and full range. Is that testing the memory the hardest? Thanks
T Technonut Diamond Member Mar 19, 2000 4,041 0 0 Jun 6, 2004 #2 Is that testing the memory the hardest? Click to expand... You need the cache on, and run all tests. EDIT: Loop the tests at least overnight also....
