- Mar 15, 2003
- 12,668
- 103
- 106
So what are you guys using? From having an s6 edge I recall going through a few cases before finding one that worked with the inductive charging.
Thanks!
Thanks!
You can get ones that look similar for 99¢. But given that it's the fit and finish that make the difference between a great case and a useless one, it's worth getting a known-good brand and source.
