Best router for under 120
Dec 17, 2003
86
I am looking to buy a new router or hub ( whats the difference ) for under 120$. I have zoomtown adsl, ive been having many problems with the past year with my internet cutting off and slow downloads/high ping. They told me that it could be my hub and said i needed a better one, tis a linksys 5 port work group, model number efah05w. I am going to compusa today and i was wondering what i should get, i would like atleast an 8 port, I have box and two computers hooked up to it.
Dec 17, 2003
86
was that just supposed to be a link to newegg? it gave me an error. and should he get a router or hub? if so what one. someone told me that a switch is better than a hub.
CraigRT
31,440
Do you need wirelss?
if not, you do not have to spend anywhere NEAR $120... I got a GVC router for $45 Cdn with 5 ports on it... it works perfectly, and it's a 10/100 switch also.
Frew
2,550
Originally posted by: MDE
Originally posted by: LeadFrog
I use this.
I have one too, not a hiccup for 6 months, even over a wireless connection.
Yeah, Hate to sound like a fanboy but I won't buy anything but Linksys for networking.
Caminetto
821
49
Another Linksys routers fan. And if you look around you can probably find a non-wireless for less money.
batmanuel
2,144
Another vote for the WRT54G. Even if you don't NEED the wireless, the price difference between a good wired and wireless router is so little (maybe $10-$20 depending upon the kind of deals going around) that you might as well go wireless.
Also, with the Sveasoft makes a third-party firmware for the WRT54G router that enables a lot of extra features and tweakability, making it almost equal to a lot of small-business quality routers. Discussion of this firmware.
JackMDS
29,544
421
With all due respect, your question about the differences between a Hub and a Router means that you basically know nothing about Networking and Sharing Internet.
Before you go and buy Hardware that other people like and fit their purposes, you should spend few hours doing some reading so you would understand what is the scope and what you would like to do.
You can start here:
Link to: AnandTech - FAQ. Basic Options for Internet Connection Sharing
Link to: AnandTech - FAQ. Hubs, routers, switches, DSL, LANs, WANs...?
Link to: AnandTech - FAQ. What do I need for wireless Networking?
Ignore the prices in the links above. The same or similar hardware can be found for 60%-90% less.
The Network should look like this: Diagram of Broadband Connection with Cable/DSL Router.
And should be protected.
Link to: Basic Protection for Broadband Internet Installation.
Link to: Internet infestation -Or, how you are getting Internet ?Junk? in and compromise your Computer/Network?
As far as Wired Router.
The main difference between the Entry level Cable/DSL Routers is the Firewall "Filtering" system, and number, range etc. of ports that can be opened through the Hardware Firewall.
If you are a gamer, and or use applications that need ports opening, it is an issue you have to look at.
If you need special ports opening for Server, VPN, etc. You have each targeted Router to make sure that it can keep these ports Open.
Link to: Cable/DSL Routers - NAT & Ports.
If you want a more elaborate Router with better VPN, and SPI capacities you have to look at the Top Models of SMC, Linksys, and Netgear. Each Brand has a higher level hardware for about $120
Otherwise I would go with the lowest price.
Link to: Wireless What Should I Get?
:sun:
iwantanewcomputer
5,045
I have zoomtown too at home, don't know if it's the same hub/router, but i have the same problems. the connection will just flick on and off every few minutes and the bandwidth is sometimes very low. i got a new ethernet hub and swqitched it with the other hub that plugs into the box that plugs into the wall and it didn't change anything. i think for me anyway it's just a crappy connection
