going to give that WNDR3700 a shot. Worst case scenario is that I'll return it if it acts buggy.
I'm just wondering if im better off flashing DD-WRT or if i should just stick with the stock software.
I plan on using both the 2.4 and 5ghz frequencies, and want to attach a usb hard drive as storage.
I like using DDWRT software, as its the same as the one im used to, but i dont want to risk possibly losing a feature or something like that.
Ive read on that products page that it may encounter problems because of the atheros chip and the driver. It says this:
"This router runs on the AR7161 chip, using the madwifi driver. This driver has known issues that are difficult to troubleshoot, and lead to the router to stop broadcasting SSID after random intervals, depending on client wireless card hardware. There are many ways to resolve this temporarily, but as long as you are using the same cards/hardware the problem will return. Ways of fixing it temporarily include a hard reboot, hitting 'apply settings' on the wireless page, or ifconfig down / ifconfig up the appropriate interface (in this case ath0)."
So which should i go with?
