- Jan 23, 2007
- 1,417
- 392
- 136
I just used gparted (ultimate boot cd) to create a ~40 gigabyte partition for XP, then about 900 gig for Windows 7. I got Windows 7 installed and it booted fine, then I let it install the roughly 200+ updates it wanted to do. After that, I installed Windows XP, making sure it went onto the small partition.
When I rebooted, instead of getting some sort of choice for which partition to boot to (I assumed UEFI would give me that, wrongly, I guess), it would only boot to XP every time. That's not what I wanted, so I deleted the XP partition, and after that the system wouldn't boot at all. Thankfully, a couple of tries of repairing the Windows 7 install got it back on its feet.
I don't like that XP just seemed to sort of take over. I also especially don't like how XP was able to see my Windows 7 partition as a drive letter.
Can anyone recommend a simple boot manager that will let me have XP and 7 on the same hard drive, but won't let them see each other? Ideally, it would also let me add another hard drive exclusively with Linux on it down the road, for a triple boot system.
I guess I could call what I'm looking for a sort of "chastity belt" type boot manager, where each OS/Partition is kept in the dark about the others, and they can't screw each other by changing files, etc.
If anyone has any suggestions, I would really appreciate it. My kids have some favorite old games that run well on XP, so I was hoping to have a small install of it on there as well. However, I'm staying away from XP until someone can hopefully give me a clue as to why installing it seemed to hose my Windows 7 install on another partition. Thanks for any help!
