I know you can make more permanent changes by flashing the BIOS on the video card to unlock the other 4 pipelines (i.e. Warp11 BIOS) then use another program like Powerstrip to overclock the card OR you can install the Omega drivers and change the core and memory clock rates in the display properties under settings -> advanced -> RadLinker tab. I guess using the Omega drivers allows you to set the core and memory clock rates to default settings when your not gaming, and to overclocked settings when you want to game? Has anybody tried both approaches, and if so, which gave better results? Thanks.
Note: My 9500 Pro (128MB DDR SGRAM) has four Infineon 3.3ns memory chips lined up in a straight line.
