Best Radeon DDR settings
cbsmith
I just purchased a Radeon 64MB DDR video card for my PC. I am just trying it out now, I am not sure if I want to keep it or not.
What are the best settings for driver? I have disabled V-Sync, but that is about it. Can someone please tell me what the best settings are for this video card? I am runnign a 1.2GHz Thunderbird.
Thanks,
Chris
Bump...
According to Powerstrip, my memory and engine are running at 198Mhz. This seems a little higher than what it si suppsoed to be. It is the retail VIVO verion of the card. It is really stabel so far. In Quake 3 I get 90fps at 1024x768x32 with all details maxxed. Is this good?
Chris
is it good..
what do you think? do you like it? if so, then I'd have to say it is good!
the Radeon 64 DDR recently began shipping with 5ns DDR SDRAM, and with a default clock of 198mhz. that's normal!
You can overclock it a little if you have good airflow in your casing. I can get my retail radeon 260 core 230 memory with a retail duron heatsink (no artifacts). I've got over 26% increase in this benchmark. using 1024x768 max detail with the sound off.
