Best/Quietest fan for an AMD 2100+ XP chip? Need replacement for OEM fan.
LordJezo
Banned
Don't want something that will be too loud to stand, but don't want something that will be too quiet/slow/bad to do any cooling.
Right now I have the OEM AMD fan and I really want to replace it.
Any reccomendations?
A couple ideas, that seem to be pretty universally accepted, would be:
Cheap (well, wrong connotation - how about "inexpensive") but good (and fairly quiet):
http://www.newegg.com/app/ViewProductDesc.asp?description=35-150-010&catalog=62&manufactory=BROWSE&depa=0
Midline - very nice:
http://www.newegg.com/app/ViewProductDesc.asp?description=35-106-037&catalog=62&manufactory=BROWSE&depa=0
Ultimate (note that this one requires a fan be purchased separately - Vantec is good, the "stealth" fan if you want good cooling and low or zero noise, or their "tornado" fan if you don't mind noise and simply want the best cooling available:
http://www.newegg.com/app/ViewProductDesc.asp?description=35-109-011&catalog=62&manufactory=BROWSE&depa=0
