I have the computer in the same room as the TV so when I want to actually pay attention to the TV I usually have to turn the PC off. Now this is obviously the cheapest solution but I would like to find a way to simply quiet down the PC
I believe the power supply fan is the loudest part currently. It is always running and it is the only fan pointing outside the case (the CPU and video card fan are the only other ones and they are inside the case). So I am looking for a quiet power supply. I don't need more than 400 W and I would prefer if possible to stay under $100 (after all I can just shut off the PC)
When I go out looking for quiet powersupplies there are tons of them in about every price range but usually the specs don't list how loud they are so I cannot figure out a good way to compare two different models.
Do any of you have good recommendations?
Thanks
Thanks
