- May 22, 2005
- 123
- 0
- 0
Hello
Can you recommend the best quality/most reliable external harddrive?
Is ok if not the cheapest, I just want to make sure I buy one which is not going to die on me. Size about 1T. I was going to get FreeAgent Extreme, but reviews on here don't seem that great...
Will be using to store work files, so really need a good one.
I'm also thinking of buying a NAS device. Don't know if this is a waste of money. Would set up with RAID1 to be extra sure. Want to VERY SAFELY back up less than 1T of data. Want it to be convenient and reliable.
Are these good?
WD ShareSpace?
Network Storage System
Seagate BlackArmor NAS 440
Thanks!
quanttrade99z
Are these good?
WD ShareSpace?
Thanks!
quanttrade99z
