Best PSU for $100 dollars
CubicZirconia
5,193
I want something that is stable, provides plenty of power, and is quiet. I don't need to spent $100 dollars, but I don't want to spend more. Right now I'm looking at the Antec True Power 550 watt. Any other suggestions?
elkinm
2,146
I would recomend the True Control 550. It is only $6 more and gives you full control of the voltages. If I would spend that much this is the only one I would consider.
CubicZirconia
5,193
I saw that, apparently the "core" is pretty much the same as the True Power. If I end up buying a psu (not sure If I'm going to), I might get that. I suppose it wouldn't make much sense not to, but I don't know that I would ever use the voltage controls.
Nebor
29,582
12
Zalman 400w. One of the best steps towards silencing my computer I ever made.
CubicZirconia
5,193
I realize wattage isn't everything when it comes to psu choice, but the reason I want to get a new one is that my current unit might not be cutting it. I don't think I want to go from a 350 watt fortron to a 400 watt zalman, just to end up with the same problems.
Zebo
39,398
19
I traded my "true 480" for the silentX 400 and it dominates accross all rails and is silent. Read the review and browse around the forums there. http://forums.silentpcreview.com/viewtopic.php?t=3365&highlight=silenx
Nebor
29,582
12
Unless you're running a lot of stuff, 400w should be plenty.
axemanxt40
488
Dude get the Thermaltake Silent Purepower its like 5 more bucks and its an awesome PSU! Also check out the Purepower 480 if you decide you don't need ~ 550 watts!
CubicZirconia
5,193
I already know I don't need 550 watts. I'm just tired of screwing around with power supplies and I don't want to have to buy another one for a long time. I've gone cheap twice- never again.
Schadenfroh
38,416
4
my Tt 420 watter holds up well, but im about to move to antec 380watt because its what is in my new case.
Nebor
29,582
12
Thermaltake powersupplies are notoriously noisy... don't get them.
Elcs
6,278
I dont know where you pulled that out from. I agree with Schadenfroh and axemanxt40.... Both of my Thermaltake PSU's are top quality and VERY quiet.
This article may be a bit old but according to that, Thermaltake was the quietest... beating the Zalman albeit on a very small (possibly insignificant) margin.
Nebor
29,582
12
Quite simply, Thermaltake hasn't made the cut at SilentPCReview to be put on the recommended list. I couldn't imagine getting a PS that wasn't on their list. A quick search of their forums will tell you that many people dislike Thermaltake power supplies.
Elcs
6,278
Well based upon my experience, I cant not recommend Thermaltake Power Supplies. I dont think its audible over my 2x80 and 1x92 Panaflo L1A's but I might take a closer listen when Im finished working.
pelikan
3,118
Originally posted by: biostud666
I've just bought a Seasonc Super Tornado 400W and it's really low noise due to the 120mm fan.extreme overclocking
I would get that or the 400W Seasonic Super Silencer. Here's a review at SPCR. Is very quiet, efficient, has super tight voltage regulation and plenty power on the 12V rail.
RaNDoMMAI
771
acually the PSU list needs to be updated there. I have a forton 350 and a coolMAX 400. I would of got the 300 or 350 but they were out of stock when i was ordering at newegg.
anyway i would say the coolmax is >> quieter then my forton. and the 400W version was cheaper the the forton350.
dont get me wrong, the forton is quiet, but near it i can hear a hum and from around one foot i can hear clicking. The coolmax has no hum and only from right next to it i can hear clicking from the lowest setting.
~RaNDoM
