Best project for socket 7 duallies
ken008
532
I have two socket 7 systems idle 200 and 233mhz dual . What is the best project to run ? Is it worth messing with?
Doomer
3,721
I run both ECCP and SETI on my dually and it works out great. :)
btw : Welcome to Anandtech. :)
networkman
10,436
SETI is going to take a LONG time on those, so maybe ECCp would be a good choice.. I'm not into that particular project, but I'm sure some folks who are will be along shortly. :)
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
Seti takes about 30 hours or so on my 300. I heard F@H ( folding ) recomended last time this came up, but not sure.
paf077
1,241
I have a k6-2 300, and seti took about 30-34 hrs for 1 Wu, but it's used quite a bit at work.:(
I have installed ECCp on it and it runs great, no lags or anything on that system now! :D
So if you want my suggestion ECCP is the best thing for those rigs. :)
Paf
ProviaFan
14,993
If you install ECCp, make sure to put two clients in separate folders. You can run one GUI and one CLI, or two CLIs, but not two GUIs. Also, there is a SMP client, but it is reported to be quite slow, so the two CLI is probably best.
