Personally I'm a fan of 3m's thermal pads with doublesided adhesive, it's easy to get them off again if you need to put the stock HSF back on for warrenty work and as long as they are installed properly it doesn't hurt performance much.
But if your hardcore a dab of superglue in 2 corner and tim on the rest of the sink works as well and is still removable with additonal effort.
the Artic silver stuff is like an epoxy and it's basicly permant so while it works very well and is pretty easy to use it tends to be permant.
