Best primary color of all time?!
skimple
1,283
Red travels the least distance, which is why the military uses it during night maneuvers, and all maps are designed to be read with a red filter.
dullard
26,187
4,853
Originally posted by: hypn0tik
When you mix two primary colours, you get a secondary colour...
Red light + green light = yellow light. Yellow is a secondary color for light.
neutralizer
11,552
I don't understand why people say green is a primary colour. On what basis?
because it's a primary color when mixing light... read the thread :roll:
What do you mean? Clarify please?
you missed out on physics/any graphics imaging class. red, green, and blue are primary colors of light, you mix red and blue to get a secondary color, violet. same principle, just diff with light.
hypn0tik
5,866
Are you kidding me? You mix blue and yellow to get green. Green is a secondary colour by that definition. I was asking for the definition that would make green a primary colour.
dullard
26,187
4,853
Not with light you don't. You are 100% backwards for light. For paint, you are correct. But not for light.
Do you have photoshop or a similar program that lets you mix colors of light? If so, it is easy to see.
neutralizer
11,552
Go study how a TV/monitor works.
Nov 3, 2004
10,491
22
That only concerns mixing pigments. Light =!= pigments
hypn0tik
5,866
Click me!
neutralizer
11,552
Click me!
Again, you're not getting the idea of distinguishing primary colors of pigments vs. primary colors of light.
hypn0tik
5,866
Click me!
Which is exactly what I asked to be explained...
neutralizer
11,552
Click me!
And we've posted links that explain. You just never bothered to look.
mchammer187
9,114
Click me!
ever heard of the RGB standard or RGB cables?
R=red G = green B = blue
any other color is a combination of those 3 in light
hypn0tik
5,866
Click me!
My bad. I missed them.
dullard
26,187
4,853
Others have already given example links that answer your question. But let me try to give you some explanation.
Paint:
[*]Paint absorbs light. Thus what reflects to your eyes is whatever the paint did not absorb. Thus a red paint absorbs all visible non-red light, and red light bounces back to your eyes. In a way, paint is the exact opposite of light. A blue paint absorbs all colors but blue. A green paint absorbs all colors except green.
[*]If you mix colors of paint, you can make something that appears black. The blue paint absorbs all but blue light. The red paint aborbs all but red light. The yellow paint aborbs all but the yellow light. Together, they absorb all light and you see nothing (black).
[*]The result is that every color you mix in, will reduce the light you see (they subtract as you mix).
Light:
[*]Light is the opposite of paint. If you see red light, you have only red colors, nothing else. If you see blue light, you see blue colors, nothing else.
[*]Light is additive. If you mix red light with green light, you see both the red and the green (which looks yellow). If you mix red, blue, and green light then you get all the colors and it looks white (a mixture of all colors).
[*]The result is that every light color you mix in, will increase the light you see (they add as you mix).
See the difference between paint and light? For paint, yellow is primary. For light, green is primary. That is why you have RGB monitors and RGB TVs. Red, Green, and Blue. Look at a TV very closely when it displays a white image. You'll see red bars, green bars, and blue bars.
