Best power supply?
spanner
464
I currently have 2 power supplies that are AMD approved to 1.2ghz(exactly what I am getting). As soon as I have the money I am gonna buy a new power supply with an intake fan at the bottom as this is a problem area with my case. So are there and recommendations. I would like to overclock in the future, price is a factor and so is noise.
DARRIN
2,756
Enermax 350 watt. I bought mine from kdcomputers.com about 6 months ago for around $55.
TunaBoo
3,280
Go for an enermax 400 watt non wisper. It will pump more air and it is not very loud at all (to me).
I have a 351 watt wisper myself.
madthumbs
Banned
Oct 1, 2000
2,680
I wouldn't recommend any Enermax for any Athlon over 1GHz. Check out the recommmended list at www.amd.com. There isn't a single Enermax listed yet. Enermax is working on getting compatable PSU's out to market though.
TunaBoo
3,280
<< I wouldn't recommend any Enermax for any Athlon over 1GHz. Check out the recommmended list at www.amd.com. There isn't a single Enermax listed yet. Enermax is working on getting compatable PSU's out to market though. >>
Wheres the exact link, AFAIK they used to be rated by AMD at least.
And AMD won't rate a HSF as acceptable if it is too heavy - I could give a crap less. Enermax is higher qual than 90% of the PSU's on their list.
