Best Power Supply
Ademi99
37
What brand and model is the best power supply for a gaming Rig.
I'll be running a 6800 ultra and a amd 64 processor, which power supply out there is rated number one, cost doesn't really matter.
df96817
183
PC Power and Cooling's Turbo Cool 510 Express. Very very expensive tho, at $229.00.
Ademi99
37
Well I was comparing two power supplies antec 500 truepower and ocz powerstream 520, I would like to decide between those two......
df96817
183
Antec also makes good PSUs also...
Ackmed
8,499
560
Yes, I have the ATX Deluxe.
billyjak
Not for a quality Power Supply that most people skimp on and then wonder why their Rig has problems.
User5
215
Im not a big OCZ fan, but Antec PSUs are great! Im using the 480w TRUBLU in all computers that I build for people.
I dont see how much better a 230 dollar power supply could be than the <100 dollar Antecs out there. Works fine for me.
Goi
6,772
7
You can't go wrong with either. Enermax is another one you should check out. They tend to have stronger +12V rails than Antecs historically, but Antec has been improving recently in that aspect.
ctk1981
1,464
I got the OCZ 520 powerstream powersupply. This thing is sweet! SATA connectors, shielded vga/hd connectors, adjustable rails, etc etc. Very solid powersupply. Hopefully its the last one I have to buy for a while.
Elvis2
2,710
same here. installed it this weekend to replace by Antec TP 480 because I was having locking up issues with my eVGA 6800 Ultra. this was the perfect p/s for my rig because of the two dedicated, shielded vga/hd feeds as well as the two sata connectors for my two Raptors. i also have four optical drives, four case fans, a usb hub, and an external usb 2.0 hd. even during overclocking the voltage doesn't fluctuate at all. it was $132.00 shipped from newegg. btw, the finish is outstanding and it has a five year warranty ;)
read this: Recommendation: OCZ Power Stream 520W
Price: $130 shipped
The first thing most overclockers learn is that the power supply does matter because the first wall most overclockers run into is the inadequate power supply that came with their white-box computer. Overclocking demands much more of a computer system than running the system at stock speeds. If you think a Prescott at 3.4Ghz demands wattage, then you realize quickly that a Prescott at 4.0Ghz demands even more power. The same is true of video cards. If a 6800 Ultra Extreme demands a decent 470W power supply, then you will need even more power when you overclock that 6800 Ultra to higher GPU and memory speeds.
You also learn quickly that all power supplies are not created equal. Most power supply ratings are combined ratings, as regular readers have learned in Power Supply reviews at AnandTech. This means that as some of the power supply rails are driven, other rails drop in power, and may end up supplying less than ideal power under stress. The very best power supplies individually control the power rails. They, therefore, usually handle the stress of overclocking much better than a PS with a combined rating. These are the power supplies that are most coveted by overclockers.
A superb example of a power supply geared to overclockers is the new OCZ Power Stream 520. It was designed from the ground up for overclockers, and features individual rails that are even tweakable for higher output or exact values. There are even LEDs on the rear of the black chrome case that tell you if the PS is operating in spec, under spec, or over spec. These same LEDs can even be used to tweak individual rails for optimum power.
520W sounds like a lot of power and it is, but truthfully, this power supply would probably be rated at 700 watts by a manufacturer who was trying to impress with specs. The 520W rating is conservative and this PS can easily handle almost anything an overclocker wants to throw at it. While the OCZ Power Stream are new to the market, they have quickly become favorites of the extreme overclocking community.
You will also find a stock 24-pin ATX power connector that will work with the new Socket 775 motherboards and servers, as well as a 24-pin to 20-pin adapter to use with motherboards requiring a standard 20-pin connector. There are also extra long SATA and 4-pin Molex connectors to power anything you might put in a full tower case or the CM stacker, as well as special heavy duty cables for the demands of hard drives and the latest high-end video cards. You can find out more about the Power Stream power supplies at the Power Stream product page.
taken from Anand's latest overclocking build up guide.
Gamingphreek
11,679
Nice post... i would definately go OCZ, then Enermax, then Antec and PC Power and Cooling in 3rd.
-Kevin
CraigRT
31,440
-Kevin
based on quality, I'd rate it like this:
PC Power and cooling
OCZ and Antec (probably very close)
Enermax
