Best plywood for paint?
paperfist
6,539
286
www.the-teh.com
Not sure what I'm doing wrong but all of the plywood that I've painted shows the grain. The last one I used to build a desk out of I had put like 5 coats of Behr on it and still the grain showed. It was primed as well.
I'm looking to build a fish tank stand now and I want to paint it glossy white or black and don't want the grain to show.
Greenman
21,751
6,176
Use a solvent based "high build" primer and sand it after it dries. The water in latex primer raises the grain of soft wood.
The best plywood for paint will be a hardwood plywood.
Reactions: paperfist
paperfist
6,539
286
www.the-teh.com
Thanks!
You mean cabinet grade? I forgot which type I used think it was BC sanded on one side .
Humpy
4,464
596
MDO has a plywood core that is faced with a smooth resin and paper veneer. Pretty easy to get super smooth paint on it, especially spraying. It's exterior grade so it's okay getting a little wet if you protect the edges.
Maple veneer plywood with a good core paints well. I like Zinsser BIN primer, it's not really high build but its dries hard and sands smooth. Might need a few coats.
Any plywood would work though if you wanted to spend the time filling the grain.
Hopefully you're somewhere with a legit supplier that can provide options.
Greenman
21,751
6,176
Thanks!
Anything other than fir should work, except oak, it tends to have an open grain. The stuff Humpy mentioned sounds like a hit, though I'm not familiar with the material.
mindless1
8,644
1,695
I never had a problem sanding it down first then using oil based paint. However, build a desk? If plywood worked best for everything, that's the wood everyone would use for everything...
paperfist
6,539
286
www.the-teh.com
hmm I never heard of MDO either, I'll have to look that up. Thanks!
EDIT: This stuff? https://www.lowes.com/pd/Medium-Den...r-MDO-Plywood-Application-as-4-x-8/1000049011
Kind of pricey along the lines of cabinet grade, but since it's exterior grade it would be perfect for my application for a fish tank.
Maybe that was my problem I didn't sand it because it already was from the factory.
What's wrong with a desk? It had a nice curved main deck that you could roll your chair up into. Tons of shelves and most of the flat surfaces were covered in formica anyway.
Muse
40,023
9,678
I built a ton of shelving for my computer room, used no plywood at all. It's all solid pine and I finished it with shellac, all sides. It's gorgeous.
Here's the skinny on how I finished it from my data (I did all this before assembling. This was back in 2003.):
When I did my bookshelves I basically did this:
1. Sanded and dusted the wood nicely.
2. Applied a 1/2# cut shellac coat to semi-seal it so boiled linseed oil would penetrate sufficiently but not enough to blotch.
3. Wiped on boiled linseed oil, wiped off after 5-10 minutes. Wiped off well with old socks on my hands.
4. Let dry several days, longer if the weather wasn't so good.
5. Apply two coats full strength (3# cut?) orange shellac.
6. Applied two coats of furniture wax with 00 steel wool and buffed.
herm0016
8,503
1,117
The Baltic Birch and maple ply at home centers will paint well. MDO will be the best.
Did you buy SANDE or sanded plywood? sande is a type of light weight soft wood.
