best place to mount cathods?
twitchee2
I bought 2 cathods the other day and need ideas on where to mount them. it is a dual 12inch set. i am thinking one by the IDE and ATX power plug and i need ideas for hte second. rig in hte sig.
Put one on the bottom nearest the side panel and one on the left nearest the side panel. That way, you get a nice ambient glowy effect and you're not looking directly at the cathodes.
What case do you have ??? I also like mounting them where the bulb's cannot be seen.
Much like THIS
Another PIC
Here is a PIC where the light is mounted where it can be seen...In my opinion it looks much better with the lights hidden.
These are UV blacklights with UV reactive cables and sleeving.
It's okay to me, but my wife loves it. "I would do that"--lizardth (And I'm not talking about her building it. She would **DO** it)
I have a similar problem, in that I'm running out of space for 'em!
I have four 12" and one circular 😀
As said above, I try to mount them so the bulbs arn't visable, which is hard because it's at eye level, at an angle and very easy to see into 😀
