• We are currently experiencing delays with our email service, which may affect logins and notifications. We sincerely apologize for the inconvenience and appreciate your patience while we work to resolve the issue.
Best place to buy ethernet cables?
czech09
8,990
I know there aren't supposed to be request posts etc on here but I'm sure someone knows of a good/cheap please to buy ethernet cables online.
Lubomir
Tu13erhead
3,238
Lubomir
:roll:
policy11
428
On another note, the IWANNA thread should probably be a sub-forum to Hot Deals. It's easier to look through a request forum than a request thread.
policy11
428
After googling:
"Solid vs. Stranded Cable.
UTP Solid Cable?Use solid cable for runs between two wiring closets or from the wiring closet to a wallplate. Solid-conductor cables, designed for horizontal and backbone cable runs, should not be flexed, bent, or twisted repeatedly. The attenuation is lower than that of stranded-conductor cable.
UTP Stranded Patch Cable?Use Stranded Patch Cables in shorter runs between network interface cards (NICs) and wallplates or between concentrators and patch panels, hubs, and other rackmounted equipment. Since it?s made with stranded conductors, our Patch Cable is excellent for applications that call for repeated flexing without damaging the cable. However, attenuation is higher in stranded-conductor cable, so the total length of stranded cable in your system should be kept to a minimum to reduce signal degradation in your system. It?s best to keep lengths of stranded patch cables under 20 feet."
source: http://www.blackbox.com/Tech_Support/Black_Box_Explains.aspx?cid=1286&bid=2077
Rumpltzer
4,815
33
If you want a non-online source, go to Big Lots.
It's hit or miss, but I find Ethernet, USB, coax, RCA, whatever cables there all the time for very cheap.
policy11
428
Quote from another forum:
Just echoing this guy's advice here: no serious cable installer even carries a crimp tool - the 1000' spools of cable you are buying is solid core cable and is not made for regular flexing nor is it intended to have ends crimped on them. Everyone that replies with "yeah but I make my own all the time and they're awesome dude" can pipe down until they've made them by the hundreds and had them all test out at 1000MHz on a scope. The ones you buy from a factory have already been certified, are made with stranded core cable, and are likely booted as well. Run sold core in your walls from a central patch panel to your wall jacks and punch them down with a punch-down tool. All of this stuff can now be purchased at Home Depot so you won't have to spend a lot of $$$. For the patch cables, buy them from a factory.
Originally posted by: RMSistight
Yeah seriously. I buy a 1000ft for like $30 and make them as long as I want. $10 for 25 ft? Bite me. hahahha
Uh, you can get that cable for $2.59 at monoprice.
AirMail1
312
Those of you who answer a post that clearly is in the wrong board are almost as bad as the OP for continuing the thread.
Even worse this wasnt originated by a newby but a Diamond member with over 3000 posts. Anyway while it's at the top, I thought I would chime in.
RMSistight
1,740
Yeah but what about shipping? How long do you have to wait? At $2.59 for 25 ft, you can AT MOST get about 289 ft of Cat 5 cabling for my $30 for 1000 feet. Also, you cannot make the cables as long as you want. You have to stick with 25 ft unless you want to cut the cable and rehead it again.
Ninjaneer
59
I made MANY cables at work using solid core, shielded cable and never had any problems. Granted, they aren't as flexible, but I would assume that most people don't jump rope with cables and what not. You hook em up and they work...
Moffat Cafe
450
Look carefully through trash bins, you could find some for 0 cost, perhaps in less than a year. Hint--use a good strong multi LED flashlight, then repost illigally again and ask where you can find some powerful LED flashlights cheap.
PS A better post might be, "where can I find a good replacement brain cheap".
Pardus
8,197
21
PC Micro has them for good prices and most are shipped free. Just bought a 50' cat5 cable for $10 shipped from them, can't beat that.
Here
amdskip
22,530
13
Did you read the post I quoted? Making your patch cables is not a good idea.
Exactly my thoughts, works if you are in a pinch though but I wouldn't use them.
esquared
Forum Director
Oct 8, 2000
25,047
6,152
No, this thread was bumped by a spammer. That post was removed, hence you see Macgyversites post AFTER the spammer.
Reactions: rsachoc
Mike64
2,108
101
$2.59 plus about $8 minimum S&H. If you have Prime, you can do better on Amazon these days, or if you don't mind waiting a while to get them (with their free/cheap "standard" shipping), Newegg...
ETA: Whoops, I didn't notice this was an ultra-necro thread before I posted...
esquared
Forum Director
Oct 8, 2000
25,047
6,152
Monoprice is not bad on shipping for just a single cable. I bought cables from them and shipping is cheap.
That 25 footer is 2.87
https://www.monoprice.com/product?c_id=102&cp_id=10208&cs_id=1020801&p_id=290&seq=1&format=2
25 ft flex is 3.33
https://www.monoprice.com/product?c_id=102&cp_id=10208&cs_id=1020802&p_id=11285&seq=1&format=2
In either case shipping is only 3.49
