Originally posted by: modedepe
I always build on my dining room table...
Do you attract the same degree of static electricity if you wear sneakers instead of just socks on the carpet?Originally posted by: halfadder
My buddies and I have built several PCs on my carpet floor. But then maybe all of the pizza crumbs and dust have shielded us from any potential static...
How about a tile surface? Sneakers on, off, or irrelevant?Originally posted by: ribbon13
Sneakers? Have you even seen how a Van de Graff static generator works?
Uses a rubber belt!
What's a proper ground to connect the strap to? Certainly not the chasis where the actual peripherals are? Perhaps the removal, metal side door of the case?Originally posted by: ribbon13
ESD straps are cheap people!
Why not? The point is to (gradually, not violently) equalize the voltage potential of two bodies - namely you, in reference to the components/chassis. In other words, the chassis is exactly what you should be grounded to, the one that the components are all connected to. That is further facilitated by the fact that the strap has a bleeder resistor inline with the connection, usually.Originally posted by: symbol
