Best place for info on overclocking a Geforce3!
codehack2
1,325
You sound confused? Do you want to 1) Overclock the Geforce 3 card or 2) find out how tolerant the Geforce 3 is to higher bus speeds. Apparently, there was not "'nuff said!".. if your going to ask a question, be prepared to provide details. We should not have to probe you for the info that you want answered. Gripe session over.
CH2
ramz
94
Your right, I guess I was not specific enough...How should you overclock the GF3. Is there a specific proggie, or does it require tweaking with the AGP settings in the BIOS. I remember doing this with my old Voodoo 3 3000, but thats been a while. I currently have my PIII 600E O/C to 800, and the last thing I overclocked was my watch. Thanks:p
codehack2
1,325
Hey that's better! :) The coolbit reg tweak should do everything you need.
1) Download & Run coolbits.reg
2) Go into the advanced display properties, then into the geforce 3 tab, click the additional properties button, then go into the clock frequency tab.
3) Enable Allow clock frequency adjustments & reboot
4) go to the same tab & overclock till your hearts content
Good Luck,
CH2
ramz
94
OK, got it running at 215/480..pretty stable, I'll try a bit higher later, Thanks guys!
