- Jul 11, 2002
- 1,566
- 2
- 81
Thought my new motherboard had a wi-fi chip - it does not, so I need an expansion card. Running Windows 7 with Motorola SBG6580 router. Any advice? Thanks!
With standard PCI you will endup with the Antenna stuck Low between the Box and the wall.
Thus this might be a better choice - http://www.newegg.com/Product/Produc...82E16833166046
It was more "it wasn't broke and although it probably wasn't the best thing in the world, I'd like to be back at that level, at least"So the strategy is.
If I had a Cra*y component it should be replaced by a Similar Cra*y component. :\ - :hmm: -.
In any case here is a Dual Band PCI card - http://www.amazon.com/Linksys-Wirele...+card+wireless
