Best Password Manager?
gizbug
2,621
Strong encryption, has an app on every platform (I run it on my ipad/iphone/mac/pc) so it is always in sync on every device. Support is top notch, they are always listening to feedback, and constantly updating/making it better. It will generate a PW for you if you don't want to use the same PW on every site. Then when you open your browser, you open the plugin, and it fills in the info for you. Use to use SplashID for my passwords, but after buying 1password bundle, would never look back.
Read a review of it. http://www.pcmag.com/article2/0,2817,2408348,00.asp
I think you can try before you buy also
smakme7757
1,487
Ok nice to hear. I'll look into it :)
F
fabler
Never have passwords 'saved' on a PC. Encrypted or not. Is my very humble opinion. What's not there can't be dug out by a Virus or Trojan.
Abbott
4
I vote for Roboform, I use it by 4/5 years and never had a problem...
It works on many browser with proper plugin adaptator.
stockwiz
403
15
lastpass isn't perfect, it's mobile apps could definitely use some tweaking, but it's the best I've come across. Love the 2 factor authentication options. All my passwords are now random gibberish on important sites (not forums) and I don't know any of them really... I also don't know my lastpass master password.. it's randomly generated gibberish of 32 characters that I put on a laminated QR code, stored in my wallet and safe deposit box, and scan in with a 2D barcode scanner (code corporation CR2500 I got off ebay for 30 bucks that works great)
coasthub
www.mohamedalioui.com
One word, it's Lastpass.
I've been using it for almost 2 years now. It saves my day. When dealing with passwords it generates high security password and it's FREE. Go with it as I did, you will love it as I did :)
