Hi all i am thinking of buying the new MSI K8N Diamond plus motherboard, the problem i have is that i have been a fan of ASUS and have had there last 3 SLI motherboards of which i have not been happy with.
Well i am totaly into overclocking and have an Opteron 165, balistix ram, 600w Enermax PSU, 2x Gainward 6800gt's,
what i am looking for is a motherboard that does what i says it will do, yes the asus a8n32 was a great motherboard but has a limitation on the voltage if useing the new E4-E6 stepping cores of which would only give a max voltage of 1.58v of which the asus spec said 1.76v, it did get my opty 165 to 2.9GHz but i no it had more in it and that the asus was holding it back so What i am asking you chaps is the MSI K8n DIAMOND PLUS a great motherboard, can you play with all the coms settings without any limitation, or do you think that the DFI motherboard is better, If you think the DFI is better which one should i get to run sli and max overclock on the CPU.
any help on this would be great.
