- Mar 26, 2011
- 4,310
- 8
- 81
I'm looking to replace my HP W2207, which is now starting to show its age with its 1680x1050 resolution. Overall, though, I loved the monitor apart from the glossy screen treatment and the fact that color reproduction was a bit off even after some calibration. Contrast and black levels are fantastic, however. It has the ability to pivot (rotate) and swivel, and the base is pretty sturdy and the monitor itself has a minimalistic look. It also has a 2-port USB hub, but I could do without that. For me when gaming input lag or ghosting was never an issue, probably because now that I tested my reaction time it was in the 250-270ms ballpark.
I'd want similar features to this one, but I'd also like a higher quality panel with higher resolution (whether that is VA or IPS) and if it would be possible to get the same or a bit higher screen real estate (in height, that is) that would be a great bonus. I'd also prefer a matte screen. I was looking at the Dell U2311H and it has all the requirements, except one: its height is lower than my current monitor, which is kind of a bummer. I'd be willing to give up some features as long as it's a high quality VA or IPS panel that's a bit bigger than what I currently have. Unfortunately that means either 24" monitors at 1920x1080 or 1920x1200, which I'm sure would be pretty difficult to get at this price. Are there any options?
TL;DR:
I want a VA or IPS panel monitor with good build quality, features like swivel and maybe pivot, 1920x1080 or 1920x1200 resolution, and a matte screen. It should be 23" minimum with 24" being preferable.
TL;DR:
