I just bought an 02 Chevy Prizm with the 1ZZ 1.8L (AKA: Toyota Corolla) with 68k about 1 month ago. After doing some reading online, a common complaint for this car/engine is oil burnoff... upto 1 quart per 1,000 miles is normal according to Toyota themselves. Which is just plain craziness, but I digress. I checked mine out and sure enough it was just over a quart low after driving just 1500miles...
I understand that burnoff occurs when the oil hits it's high temp limit (around 400F for pretrol based oils) and the oil starts to burnoff. Synthetic oil (which I have used in every vehicle I've ever owned except this one) has a higher high temp limit, so it burns off less. Having 70k on the car now, I'm hesitant to start using synthetic as I don't want my engine to start leaking from all it's seals, etc. When I had the car inspected, the mechanic said it had a small leak on the left side of the engine, but didn't elaborate.
I went and got two quarts of Castrol GTX High Mileage, which advertises a 17% better burnoff rate compared to "the leading petrol oil".
Should I just move this car over to synthetic or stick to high mileage petrol based?
Jugs
Jugs
