KeithF1138
We use Cable for high speed internet. The connection comes into the basement where there is a panel for connections, etc. I am upgrading the network solution and want to simplify/improve.
We use OOMA for Phone
Couple of Xbox 360s most hard wired in the house
Number of wireless devices/printers/Wii/etc.
Couple of hard wired PCs in the house
Couple of hard wired DVRs in the house
TV hard wired in the house
Currently Cable comes in to a Cable Modem which then connects to a Netgear WNR834Bv2 Wireless Router (which isnt being used for wireless connections) for DHCP for the Network.
OOMA device and Netgear GS116 16 port gigabit switch connected to router.
Connected to the GS116 are:
So this is what I am thinking about ordering
TRENDNET TEG-S16DG 16-Port Gigabit Unmanaged Switch
TRENDNET TEG-S50G 5-Port Gigabit Unmanaged Switch
Linksys E4200 Wireless Router
Want to put the E4200 as the main Wireless in the basement and connect to Cable Modem.
OOMA device and 16 port switch connect to E4200
Windows Home Server connected directly to switch
5 port switch in the entertainment center for those devices (forget the Wii it is just a dust collector) connected to 16 port switch.
Other hardwired devices connected to switch through patch panel.
Remove the other wireless routers in the house.
Want the Xbox 360s to have no problem seeing each other no matter if they are wired, unwired, plugged into different switches.
I have had spotty coverage in the past with Wireless Routers in the basement. Think the last time I tried to use a Wireless Router in the basement it was a Wireless G router. If I need it elsewhere then wiring is a hassle because the E4200 needs to be between the Cable Modem and the Switch.
Thoughts?
- Windows Home Server
- Cisco WRT400N on 2nd floor is main wireless for the house.
- Wireless Router on 1st floor in AP mode in Entertainment Center, but wireless connection only used for a Wii. An Xbox 360, TV, DVR and BlueRay player all hardwired to this Router. It is little cheap D-Link device.
Thoughts?
