best music solution for droid/mac
Agentbolt
I am moving from an itouch to a Droid, and my whole music library is on itunes. I tried using side-whatever (blanking on the name) but it either crashes or doesn't move my playlists over. I NEED playlists, my podcasts need to be in playlists so they can come over onto the droid.
Any suggestions? What do you all use?
An iPhone 😀
But really, I can't help you out much. How does the Droid normally sync stuff? A special app? Can't you just point it to your library and sync?
An iPhone 😀
Yeah usually you just drag and drop songs and playlists. Unfortunately iTunes doesn't do m3u playlists.
Doubletwist, THAT'S what I tried. Unfortunately with the Droid at least it's buggy as hell.
Ended up using Sailing, and it worked great. Even did my pics and podcasts so I don't have to manually make folders for them. Great little program.
I would stay away from Doubletwist, if anyone else is in the same boat. It double copies stuff, playlists don't make it over, if you update a playlist it replaces the whole thing with the one replaced song, etc. No good.
