Best MS duo for psp's?
I'm looking forward to buying a 1gb model and I figure I might as well get the best model out if possible. anyone recommend any certain memory sticks would be great. thanks :]
Well Sandisk has the rights for all formats of memory...including the memory sticks...so I would stick with the company that owns the things instead of going with one that bought the rights to make the MS's. For the best get one of the Sandisk ultra's but I doubt it would be worth too much of a cost increase
Get a SanDisk Memory Stick Pro Duo. Doesn't matter if it's "gaming" or whatever. I got mine from Outpost.com for like $84 with overnight shipping.
SanDisk's MS Pro Duo's are almost 3x faster than Sony's. I can't find the benchmarks ATM, but if I find them I will post them.
As others have said, get the SanDisk. Avoid Sony like the plague. I've tested both and SanDisk is multiple times faster. Sony is seriously 3 times slower.
I also tested the SanDisk UltraII version and the regular version. Don't spend extra for the Ultra. I couldn't tell the difference in speed and I tested on my PSP and my Sony F717 camera.
