Best motherboard for overclocking?
Bona Fide
Banned
Jun 21, 2005
1,901
I went to DFI Street and was turned away by the fact that they require a 24-pin connector and at least a 480W PSU. Also...the colors were less than appealing to me.
Could someone recommend to me a good overclocking board that can meet the following requirements?
- Athlon 64 3700+ San Diego (939)
- nForce4 Ultra or SLi chipset
- SATA support
- 20-pin OR 24-pin connector support
Capt Caveman
34,543
651
All nf4 motherboards require 24pin psu's and support sata. If you plan on overclocking, 480w is a good starting point for psu's.
js9600
11
You need a 20->24 converter, not necessarily new powersupply. MSI should have one included in package, I got one at least.
Where does it say DFI needs 480W psu? You need good quality psu more than high numbers, I think my junior model from OCZ Powerstream series would run any DFI just fine - even if only 420W. Depends on use/needs. Weak 12v line might give problems for a 500W psu designed for older motherboards.
Siddy
75
As said above ull need a good PSU and a 24 pin connector for all of them, but im running my A8N-Sli deluxe with a "ISO" (cheap brand) 350watt 20pin (shhhh.. dont tell anyone) but i never push it so its fine, well sum times unstable. If i overclock at all then its unstable as!
n yusef
2,158
DFI says 480W PSU, because they don't want to sya things like "of a quality brand," "with high +12V amperages (what is high?)?," etc. A 400W+ of a good brand with high amps is recommended for overclocking though. If you really don't want the DFI, then EPox got a really high FSB on AT's review.
EDIT: Added link.
Zim
1,043
4
Originally posted by: Viperoni
My system ran fine with only my PS's native 20pin connector.
Does the 20-pin plug just push into one side of the 24-pin socket?
Anyone know if the MSI Neo4 Plat (non SLI) comes with a convertor? Mine arrives at the end of the week and it would be a bummer if I couldn't get it powered up over the weekend.
EDIT: ok, I ordered one for $4 shipped off ebay. Better safe than sorry. :)
Dav373
82
mine did too, just put it into one side and it popped right in. haven't had any problems and i have an overclock of 272x9 (2.45) on a 3000+ venice. DFI nForce4 UT SLI-dr mobo.
Bona Fide
Banned
Jun 21, 2005
1,901
Interesting...yeah I was looking at the Epox board as well. I'm not gonna be requiring any serious juice to be running to my RAM, so I don't need DFI's 4.0V upper limit. And it's about $25 cheaper too. :)
FlyBono24
183
I thought we were talking about motherboards.... how the hell did this turn into an argument about power supplies? :p
Zim
1,043
4
In the same way it turned into a thread on complaints about it becoming a thread about powers supplies. :p
Bona Fide
Banned
Jun 21, 2005
1,901
LoL.
Well the DFI motherboards insist on using 24-pin ATX connectors...none of that 20pin-to-24pin convertor stuff. So I guess it stemmed from there ;)
Jaxidian
2,230
twitter.com
ryanv12
920
They do? I was going by the sticky that's posted in the General Hardware forum and I was assuming my Antec Truepower 480Watt would be sufficient for any nf4 motherboard except the DFI ones.
It also says not to use the 20-24 pin converter...is all of this still true?
I'm buying a PCI-E motherboard so I can get a 7800GTX but I ain't buying a new power supply!
I'm really quite confused on what motherboard I should get.
Capt Caveman
34,543
651
Originally posted by: The Pentium Guy
Doesn't it have that 1T issue and lots of bugs?
I think you're talking about the A8N-SLI Deluxe. The 1T issue on the Deluxe has been fixed w/ the latest bios update.
From everyone that has the A8N-SLI Premium, there haven't been any issues to come up yet other than user error. The premium is a kick-ass motherboard(and I don't even plan to run sli).
Capt Caveman
34,543
651
My apologizes. I meant that all nF4 motherboards have a 24pin power connection. You may be able to get away with a 20pin psu with an adapter. But based on number of components, video card power requirements and overclocking, you may need a 24pin psu to maintain stability.
ryanv12
920
Gotcha. no need to overclock for me though, I guess it's just not my hobby. I just want it to be stable. My PSU has 28A on the 12v rail I believe, and that's juicy enough for me :)
Thanks.
Capt Caveman
34,543
651
Thanks.
No problem. And yes, you'll be fine with that juicy 12v rail. :)
silverpig
27,703
12
I had a 1T issue but I upgraded the BIOS yesterday to the june 23rd (I think) revision and now my memory issues are non existant.
2-3-2-5-1T @ 210 MHz I believe. Was only getting 2-3-3-5-2T @ 190 before, and only could get 1T with a 1/2 memory divider (like 130 MHz speed).
GuitarDaddy
11,465
Nope, the 1T issue was fixed with the premium as well as a move to a passive heatpipe cooler for the chipset
GuitarDaddy
11,465
Tell me its true:) or better yet show me some conformation. I gave up trying after 1011-01, which one fixes the 1T problem
Zim
1,043
4
Originally posted by: Capt CavemanMy apologizes. I meant that all nF4 motherboards have a 24pin power connection. You may be able to get away with a 20pin psu with an adapter. But based on number of components, video card power requirements and overclocking, you may need a 24pin psu to maintain stability.
I'm reading the manual for the MSI K8N Neo4 mboard and it tells you that you can connect a 20-pin plug to the 24-pin mboard socket (leaving 4 pins at one end unfilled). The socket is keyed in such as way as it's "fool proof".
