Best motherboard for me?
MithShrike
3,440
OK, Many of you out there use those Coppermine Celerons so what do you all think is the best board for gaming and overclocking? OK that's it and thanks for your input.
Vette73
21,503
9
Do you already have the CPU??? If not then it would be better to get a P4 or a Athlon XP. The Socket 370 is pretty much dead(expect for the Via C3)
A Athlon XP 2000+ can be had for less than $99
piasabird
17,168
60
I own an Asus TUSL2-C Tulatin Core Motherborad (1.2 Gig Intel Boxed Celeron). I have only ever tried this motherboard with the Tulatin Core 256 k L2 Cache Celeron processor. It is the only Celeron system I have ever purchased. I think it will overclock, but I never tried it. I wouldn't imagine Asus would make a full sized PIII/Celeron Board you could not overclock.
Zap
22,377
7
If you already have the CPU and just need a mobo, get one which uses the VIA 694T chipset. You'll have an AGP slot (for a good 3D video card), support for Tualatin CPUs (if you get the itch to upgrade CPU for cheap) and support for those dirt cheap high density sticks of SDRAM you see on Pricewatch for $30 for a 512MB stick. Speaking of which, it will support 1.5GB RAM unlike the runner up chipset, the Intel 815EP B revision, which only supports 512MB maximum. As to _which_ 694T board to get, depends on what one is available. Recently Newegg.com has had the Shuttle AV18ET board for around $60. Basic board with integrated sound and basic overclocking (FSB and vcore). I've had much better luck overclocking with the Abit VH6T because it's more intelligent on the AGP/PCI dividers so you can get in-between speeds to work if you can't get 133FSB, but the board was more expensive and now seems sold out everywhere.
