Best Motherboard for 8350 cpu
jtprit
Hi all,
I was wondering if I could get advice on the best motherboard and ram for a fx8350 cpu? I would like to stay under $250 for the mb and ram. I will be getting 32gb of ram. I really want a board that can handle up to 64g ram but there doesnt seem to be very many. I love Asus and was looking at the M5A99FX PRO R2.0 but it seems weird to be buying a motherboard that has been on the market for 3 years. Also I haven't been able to find any AMD boards that can handle quad channel.
Thanks in advance for the advice!
1) Don't buy an FX-8350, it's nearing 4 years old at this point.
2) There are no quad channel AMD boards.
Go with an Intel i5 or i7, AMD just doesn't have anything that can compete available.
You are way late to the AMD FX game. Almost all of the decent boards have dried up and are no longer being sold on Newegg. The new AMD AM4 platform is about to be introduced next month which is why. The new AMD Zen Octocore will be released in Q4 2016 later this year.
THAT will have quad channel memory support.
If you absolutely must build an AMD FX system with that budget I would recommend
Gigabyte GA-990FX-UD3 R5 - $100
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128859
and for memory
Crucial Ballistix Elite 2x8GB $74 x 2 = $148
which will come in just under your budget after rebate and shipping.
Unless someone has a gun to your head and is telling you to build now, I would wait. I am really curious to see what Zen is going to be like.
Well I broke down and went with the following. I always seem to have to build a system in between technologies. I guess I cant complain though since I am still using the system I built 9 years ago with all the same parts(except hard rives of course) and it runs 24x7. Unfortunately I need more memory to run the apps I am now so I couldn't wait. I wanted to go cheap but remembered in the end cheap = waist and a headache.
ASUS Z170-PRO LGA 1151
Intel Core i7-6700K 8M Skylake Quad-Core 4.0 GHz
G.SKILL TridentZ Series 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 3000 (PC4 24000)
Why would you "have to" build anything other than buying it when it made more sense ?
You will be happy with this. Nice board.
