- Aug 25, 2001
- 56,587
- 10,225
- 126
https://www.newegg.com/Product/Product.aspx?Item=N82E16824994001&ignorebbr=1
Looking at the ergotron Neo-Flex stand. It has vertical height adjustment, as well as tilt and rotate.
That monitor is a 28", which is at the upper-end of what might be possible to fit onto that stand. The monitor does have VESA 100mm mounting holes, towards the upper portion of the display, and the stand appears to be removable. (We had to assemble the stand.)
Monitor is listed as 5.7 kg Net Weight, which I don't know if that includes the weight of the stand or not. That comes out to 12.x lbs (US). If that's including the stand, then the display panel unit itself is probably 10-11 lbs. The ergotron seems to support 6-16 lbs monitor.
Another possibility, is the Rosewill stand that's on shell-shocker for $14.99 until 12:00pm PST (a few more hours).
https://www.newegg.com/Product/Product.aspx?Item=N82E16886228013&ignorebbr=1
The reviews for that one weren't universally good like the ergotron, and I would have to help my friend mount it to the side of the alcove above his desk. It's press-board, so I wonder if that would be safe, long-term. I could get two of them, and then mount both his old 23-24" LCD, and the new 28" Benq, to each side of his triangle-shaped pre-fab computer desk.
The only thing that gives me pause about the Rosewill articulated wall mount, is that this would be mounted onto some vertical slabs of press-board, and I'm afraid that too much force applied to the top of the monitor, or too much re-adjustment of the arm, might cause whatever screws that I use to mount it into the press-board to tear out and then the monitor would fall onto the floor and break.
I think that the most ergonomic solution, and the best as far as safety of the 28" 4K LCD monitor goes, would be to get the ergotron and just set it on the top of the desk, where the current 24"-ish LCD monitor sets. Not the cheapest solution (that ergotron Neo-Flex LCD stand is like $60 shipped), but probably for the best.
