best monitor choose
mkanandtech
10
please suggest me which 19inch monitor is best
1. LG196WTQ
2. LG L194WT
3. Dell SE198WFP
4. Samsung 932BW
5. Veiwsonic VX1932wm
please also tell the current price
thanks in advance
manoj
Billb2
3,035
70
86
We have no idea what you're going to hook it up to,
nor what you're going to use it for,
nor where you want to buy it from (Online/Big Box store).
It would be better to post links to the manufacturer's websites (the specs.) instead of just the model numbers.
And to post links to the places you would consider purchasing from.
That way anyone responding wouldn't have to spend a lot of time searching and gathering information for you.
But then, if you did that, you'd know the answer to your question.
