best modular power supply currently available
wpshooter
1,662
Is there any modular power supplies currently available that would be a better choice than the Ultra X-Connect brand ?
Does anyone makes a modular supply that would be competitive to the X-Connect that would have connector cables which are not quite as stiff as those that come with the X-Connect brand ?
Thanks.
tomoyo
418
I think almost any other modular would be a better choice than an X-Connect. It makes me sad to say that too. If you were comparing against an Ultra X3, then you'd be comparing good products where it's hard to determine what is best.
Corsairs/Antec have some easy modular choices with the HX and Neopower series. And yes another good choice of would the Ultra X3 series, which is lightyears better than X-connects
MarcVenice
Moderator Emeritus <br>
Apr 2, 2007
5,664
Even the Ultra X-finity's dont seem to be that good. Only good Ultra product is the X3. But those come a lot more expensive.
