Best mobo for e2140/60 to OC with under $70?
Lunyone
482
I was just wondering if there is a good solid mobo to OC an e2140/60 with a stock HSF? I would like the mobo to support DDR2 800mHz w/4 slots and have at least 4 SATA connections for future upgrades. Is the Abit IP35-e still the cheapest to reach a decent OC on stock HSF? What OC do you think I can reach with a stock HSF? I've read some where that someone reached 3 gig on stock HSF, which I would love to do, but not sure if this is likely with an e2140. I read part of the Abit IP35-e review post and thought that it was quite interesting. So there is my question. Thank you in advance for any help you can give me.
SerpentRoyal
Banned
May 20, 2007
3,517
IP35-E should work well with E2140. The stock cooler is good up to about 3.0GHz. Note that maximum FSB of these chips is limited to about 425MHz. You can get IP35-E @ MWAVE for $71 AR.
Lunyone
482
Is there another mobo, without MIR that would do as well as the IP35-e?
SerpentRoyal
Banned
May 20, 2007
3,517
You can look at the Gigabyte. About $90. It doesn't overclock as well as the IP35-E. Both should be able to take a capable chip up to 3.0GHz.
Lunyone
482
The p31 or the p35 version? Which one are you referring to?
Lunyone
482
Would a p965 chipset work well to OC a e2140/60 to about 3 gig on stock cooling?
Zap
22,377
7
I've only used one P965 chipset board recently, and that is the Biostar TforceP965. I actually had around 4 of them and none of them would take an 800MHz FSB chip up past around 350MHz BIOS setting, almost as if there was a fabled "FSB hole." Same chips were fine on both my Abit IP-35E boards to 400Mhz (double restart and all). I had sold one board to someone who had an E6300 and it went up just fine, so I'm thinking a FSB strap issue, but not too sure because I BSEL modded one chip and it still had the issue though it would initial-boot at the higher speed.
Lunyone
482
Cool, thanks for the info. I just haven't bought for an intel chip since the P4 3.2 Prescott that I have on my son's computer, so I just wanted to make sure I was getting what I needed to run an e2140/60 smoothly.
SerpentRoyal
Banned
May 20, 2007
3,517
P965 is bad for 800MHz chips.
How so? I have Asus P5b-e and it took my e4300 to 3.01ghz (334x9).
Those P5B Deluxe boards are rare exceptions. They run hot and require more Vcore to achieve the same level of overclock as a P35 board.
