Hi, well I just bought my the dfi mobo with a venice 3200+ (what a stupid mistake not waiting a bit later) my old memory isn't gonna cut it.. so any good compatible ram with the mobo at around 100 - 150?
thx for the recommendations here.. voltage isn't a problem since the dfi board supports up to 4volts
andrew.. actually i am running bf2 with just 3200+ not oced yet.. not on high res since its on the 27" syntax tv which only goes up to 1024x768. I'm not an hardcore gamer so it does the job
