- Nov 13, 2019
- 8
- 1
- 71
Hello,
I currently have:
i5-4460 + H81 (with one ram slot either by MBD or CPU dead)
500 Watt decent cooler master PSU with 6-pin connector
ASUS Geforce 960 2GB
Both the CPU and GPU VRAM heavily bottlenecks the system
I have following options in used market:
i7-4770 (65$)
i7-4790 (70$)
i7-4770K (80$)
i7-4770 + MBD + 8/16GB RAM + Cheap Casing + Cheap PSU = 125$
Ryzen PCs were starting from 225$
RX-6600 (250$)
2060 Super (250$)
1660TI/1660S (180$)
3050 (NEW) (360$)
My upgrade plan is:
Purchase complete i7-4770 system, and swap its MBD+CPU with the existing ones
Preferably buy RX-6600 and use molex+6-pin to make a 8-pin connector
Alternatively buy 1660TI/S and use molex+6-pin to make a 8-pin connector
Thus in 300$ or 375$ I will have upgraded by existing PC and have another similar PC
My expectations:
Playing games released by 2020 with stable (non-stuttering) 30fps
Is my build okay?
1. What YOUR PC will be used for: Gaming.
2. What YOUR budget is. TOP MAX 450$
3. What country YOU will be buying YOUR parts from. Pakistan
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
Used marketplace, feasible options are listed above
5. IF YOU have a brand preference. No
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are. PSU
7. IF YOU plan on overclocking or run the system at default speeds. Little bit CPU OC if possible
8. What resolution, not monitor size, will you be using? Currently 1080p, later 1440p
9. WHEN do you plan to build it? Within a month
10. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software? No
I currently have:
i7-4770 (65$)
i7-4790 (70$)
i7-4770K (80$)
RX-6600 (250$)
2060 Super (250$)
1660TI/1660S (180$)
3050 (NEW) (360$)
My upgrade plan is:
My expectations:
Is my build okay?
