Best Low Wattage PSU
aatroxed
I have an older spec rig still on the LGA 775 socket (Core 2 Quad 6600). Sadly PSU died and need a replacement. Other components include GTX 760,1 SSD, 1 DVD, and 1 SATA Drive.
Read this: https://www.anandtech.com/show/12070/the-corsair-tx550m-80plus-gold-psu-review
Comments ripped on review for suggesting 550 W for average joe.
I will upgrade in the future but still stick with 1 GPU. Any recommends? Preference is for semi modular and less than $150 (cheaper is better)? If the newer, quieter designs work with my rig, that's great as well. I had a Seasonic before so I'm biased to that brand but I'll take quality wherever and as close to my wattage needs as possible.
Here's what I scrounged up:
Seasonic Focus SSR-450
SeaSonic Platinum Series SS-400FL2
SeaSonic S12II 430GB
EVGA SuperNOVA 550 G3
be quiet! PURE POWER 10-CM 500W
Any of those are perfectly fine. I'd just buy any decent quality PSU you catch on sale. You'll lose a little efficiency buying a larger than needed PSU, but with gold and above efficiency, it won't really be very much. I wouldn't pay anywhere near $100 for a platinum PSU for such an old system.
If you want to buy it at Newegg, I'd take a look at these unit:
https://www.newegg.com/Product/Product.aspx?Item=N82E16817139210&ignorebbr=1
https://www.newegg.com/Product/Product.aspx?Item=N82E16817151189&ignorebbr=1
And if you're an Amazon Prime customer, this is outstanding deal (a little bigger than you need, but not too bad):
https://forums.anandtech.com/thread...4-90-after-15-mir-prime-members-only.2534747/
But if you want to spend a little more for whatever reason, it won't hurt anything if you plan on reusing it in the future. I currently own a EVGA Supernova G3, G2, and P2 and a Seasonic Focus Plus Platinum, and they're all great power supplies that you can't go wrong with.
