Nightmare225
What is the best socket LGA775 air cooler? My Zalman is giving very unsatisfactory performance.
If by "Air Cooled - Price is no problem" you mean a non-water cooled solution, then by all means that would be the Asetek VapoChill LightSpeed (AC)!Originally posted by: Nightmare225
However, I doubt that your pockets are that deep... 😀
With a Vapochill LS, you'll be able to run your E6600 @ 4.0 gig 24/7 benchmark stable!
If you're talking about "Air Cooled" in the catholic sense, then a Tuniq Tower 120 is your best bet!
With a Tuniq Tower 120, and enough fooling around -- lapping everything -- pushing enough air, and all that sort of stuff -- you might get to 4.0 gig benchmark stable, once or twice, but probably NOT 24/7...
Don't be a dweeb!Originally posted by: Nightmare225
Alrite, the Tuniq looks like it'll fit my needs. 😉 Any other thoughts on the Tuniq and maybe other alternatives?
WoW!Originally posted by: TheDrake
I personally like the Zalman 9700. Its lighter than the Tuniq. Check out this site.
Only heatsinks that Frostytech has tested are included in these Top 5 lists; as such FrostyTech guarantees this list is incomplete, that some heatsink models available on the marketplace are omitted, and that it is not a permanent indication of what "the best heatsink ever" actually is.
Originally posted by: Yoshi911
try this puppy on for size boyz You want a BEAST
HERE she BE!
man did this have me drooling when I found it...
The Tuniq Tower 120 is totally absent! What a shock!!!
Makes me a believer... 😀
*edit*
Oh, okay, I missed the 'fine print' on the first read:
Originally posted by: Nickel020
The Tuniq Tower and the Scythe Infinity are currently the best air HSFs. The performance difference betwenn them is marginal.
And Canai, are you sure your room temperature is 15°C? That's pretty cold, 22°C is about the normal room temperature, don't know much that is in fahrenheit. Your motherboard temps sensors are probably just off...
