Best LCD monitor for games
JJADAMS
161
Hi all, I know this has been talked about before, I am at work and really cant surf to much. Can anyone tell me where there are good reviews on todays LCD's? I'm looking @ the sony SDM-X73. Does anyone know about this one? i would like a 17 in because of price, Thanks all
g4m3r
25
From what Ive been told, and know from experience, LCD's are actually bad for gaming due to there response time being slow (This is from what I hear) And if your playing FPS thats what its all about, It could mean the difference of your aiming hitting and not hitting.
I use a Laptop atm while I wait for my comp, (been using it for 1 year) As soon as I switched to a CRT (WCG canada) my LG (Lightning Gun in Ut2003) Went from 32% to 44%. I dont know if it was luck, but the shots didnt seem fluked. I heard there are quick response LCD's but I still have to do a bit of research on those, my guess is there expensive.
VIAN
6,575
I think that this might be better. Sony has a lot of brightness on that 400 cd is insane compared to all the ones that I've looked at. You might want to check that first hand before making a choice, but the comarison is definitely close. I'm guessing that because the higher end ones don't have that high of a brightness, it may be a typo and can be overlooked because the priemierepro lacks it. Based on this, i would choose the viewsonic.
billyjak
I have the Hitachi 17" CML-175sx and it has a 16ms responce time, absolutely no ghosting whatsoever with everything maxed.
A LCD with a 16ms respnce time is very fast indeed.
