Best Jabber IM Client
kevnich2
The name says most of it, I just setup Jive IM (now called wildfire) and it's working pretty well. Anybody have any ideas for a simple to use yet powerful IM client based on jabber? The spark one is very nice, very simple to use but my employees like sending the smiley face type things every once and a while, things like that. I'm also looking for one that integrates with windows explorer for file transfers so they can right click on a file and a send to is integrated with the right click for IM file transfers. What do you all use for corporate IM clients?
I was setting this up at one point (we decided not to use it) and while testing we were using the Psi client. It is pretty easy to use and has emoticons, although it doesn't integrate into explorer. Also, there is a list of clients on the jabber site you could check out.
Thanks I'll take a look at that. The server side was very easy to setup. We'll probably end up using it (it's free and has everything my boss and I want) I just want to make sure I have the correct client program before I deploy to all the pc's
