Best ice cube trays?
TridenT
16,800
45
i have that in my fridge. after having it 3 years no there is no way in hell i would go back to doing it by hand.
having the ice/water in the door is very nice. i have it hooked up ot my RO system.
Hey.. I ain't hating on that system. I had it for about 10 years. It was nice. I just happen to have moved to a place where the refrigerator is small and doesn't have that.
TridenT
16,800
45
That is pretty good. I like the crushed ice you get out. It seems to have gotten rare over the last couple decades, but it's always super special when a restaurant has it.
If I could make pellet ice... I would.
A pizza joint here does it for their drinks. It's pretty nice. I was like, "Ooo... nicely crushed ice? Mmm..."
Locut0s
22,205
43
So you post about how everything in your life is fail and now you can't even make ice cubes. :(
Elbryn
1,213
80 posts and no references towards ice cube spheres? i got me some free trays from makers mark which require some warm water running to get them to come free but it works.
Howard
47,982
10
Even with RO I hope you are still cleaning the system on a regular basis.
zinfamous
111,095
30,041
by the way, I see very little need for ice. One of those weird American things that I simply don't understand anymore. While young I couldn't live without, nor could ever imagine a life without ice in my drinks--yet as I grew older, realized how stupid it was.
I have two ice cube trays in the fridge, and they are probably depleted once a month.
ahenkel
5,357
Only time I ever plan on having ice is if I'm having booze. A gin and tonic chilled from the fridge isn't the same as one on the rocks.
yh125d
6,886
Most of the cooling that the ice does to your drink is from the melting. The energy required to go from solid -> liquid is much more than the energy required to just go up in temperature.
What? You're right with the first sentence, but the way the rest is worded doesn't make sense to me.
The ice is endothermic, meaning that it is receiving energy from the liquid, causing it to melt. The liquid is exothermic, because it is losing energy by applying it to the ice. As the liquid continues to lose energy, it cools.
zinfamous
111,095
30,041
yep, same here. I don't drink liquor too often these days, but when I have a bottle of gin or Vodka (for glorious white russians), the ice goes into overdrive.
though I do keep my cheap gins or vodkas in the freezer. still use ice.
coldmeat
9,194
79
It's the phase change, not the warming of the ice that cools your drink the most.
waggy
68,143
10
What procedure do you use?
the fridge manual has instruction on how to do t his. i have only had teh fridge 2 years and been about a year. think it was a mix of water and ahh vinager
yh125d
6,886
What? No. You don't need a phase change for ice to cool a liquid.
Take ice cubes at 0F, pour in some vodka at 20F. the ice will not melt, since the entire system is below its freezing point, but the vodka will still cool down even more because it has more energy than is present in the ice, and energy from the vodka will transfer into the ice to reach equilibrium.
Sluggo
15,488
The best ice cube trays are the ones in the built in ice-maker.
2nd best are the aluminum ice cube trays. The aluminum conducts the heat away quicker. And, as an added bonus, they have a long lever to release the cubes. Note: lever - simple machine. A device made to make work easier to do. This makes it ideal for TridenT.
This of course would lead to the "My tongue is stuck to the ice cube tray, what now?" post.
Mr. Pedantic
5,027
A substance cannot be exo- or endothermic. The process of heating or cooling is.
He's right. At freezing point, the only process that energy put into a solid goes towards is phase change. It's just that you don't notice the ice melting because enthalpy of fusion is so much greater than specific heat capacity. Your example doesn't work because in reality, who drinks vodka at -7C?
yh125d
6,886
I meant it as in "In the system of ice cooling a liquid, the ice is endothermic, as it is absorbing energy"
Except in my example, we're not at freezing point, we're well below it.
And plenty of people drink their vodka cold
Mr. Pedantic
5,027
Prove to me that it is a common occurrence for people to drink their vodka at -7 degrees centigrade.
PlasmaBomb
11,636
Proper RO system or just a filter?
You know you aren't supposed to drink RO water long term right? It has very low levels of minerals and can potentially cause decalcification of your bones...
