Best hybrid car
thomsbrain
18,148
The Accord hybrid has inflated fuel economy numbers. When it comes down to it, its fuel economy is the same as the Camry Hybrid while being more expensive. Toyota knows how to make a good, reliable hybrid.
Car and Driver achieved 41 MPG in their instrumented testing of the Accord Hybrid (including acceleration and top speed tests).
They achieved 31 MPG in the Camry Hybrid. Even the non-hybrid Accord sport earned 29 MPG in their testing.
These two cars aren't even in the same league. Please pack your things and go home.
tortillasoup
1,977
That's car and driver. I don't know how the hell they got only 31mpg, everybody I know gets around 38-42mpg in that car. Consumer reports got 38mpg avg on their Camry Hybrid and 40mpg avg on their Accord Hybrid. Most tests I've seen shown this close range in fuel economy, so I think Car and Driver is an outlier.
Thump553
12,742
2,517
In a way you are comparing apples to oranges. The Volt, for example, is designed for those with a short commute and short daily usage. After you burn through the electric only range you are running on premium gas (to run a generator).
The Prius (regular version) is an all around commuter car. Rock solid Toyota reliability-I drive one 30k plus miles a year (60/40 highway), the only repair I've ever had to do was replace the ICE's water pump. The Prius is a light, relatively large car and will get blown around some. Not so much that an observant driver can't easily handle, but a condition you have to stay on top on windy days.
The C-Max is substantially larger than the regular Prius, more comparable to the Prius-V. Lower mileage than the regular Prius but fine. Ford managed to shoot themselves in foot repeatedly in rolling out the car by (a) lying about its mileage and (b) saddling it with what I and many see as an over complicated, buggy infotainment system. Finally, when I was researching buying one I ran across several complaints on the net that the C-Max over-reported its gas mileage, that pencil and paper calculations consistently resulted in several MPG less.
I was impressed with space of the C-Max though. If you find one comparably priced to a regular Prius (same year, mileage, etc) I'd probably go for that. But since I tend to drive cars into the ground I generally could car less about resale value.
vi edit
62,480
8,340
I wouldn't say the C-Max is substantially larger than the Prius. It's taller, but that's about it. It's actually a bit shorter and has a shorter wheel base. It does well with the way the seats are laid out and how they work the roof height. Other than that, there's not a ton of size difference. If anything, I think the hatch space of the Prius is more useful. The one place that it thumps the Prius is the engine. It will get up and run when you want it to. The prius, not so much.
No question on fit and finish, C-Max is 2 more levels more upscale than the Prius.
tortillasoup
1,977
If you're concerned with space, go with the Prius-V which has similar fuel economy to the C-max but is a LOT larger vehicle.
desura
4,627
129
101
So looking at used prices, curiously, the C-Max Energi can be had for significantly cheaper than the regular C-Max.
I think this is why:
That's pretty darn annoying to lose that much trunk space + not having a spare tire. Still, even with that, it is more spacious than a Volt.
I wonder if it is possible that whenever the battery loses too much capacity, if it is possible to simply remove the entire thing completely and get the trunk space back?
Yuriman
5,530
141
That's technically possible on mild hybrids (like Honda's Civic hybrid and Insight), but vehicles like the Prius and Accord hybrid will not run without the hybrid system.
Chevy/GM (arguably) mislead people. The gasoline engine under some circumstances will direct-drive the wheels - in fact, it uses a planetary gear set very similar to the Prius's. When they said that there is no "direct" mechanical linkage between the engine and the wheels, what they really meant was that the engine can never directly drive the wheels "alone", that even when it's driving them directly, it is also receiving electrical assistance. The major difference between the Volt's transmission and the Prius's, is that the engine is on a different "planetary element", and the vehicle can run in a wider speed envelope without the gas engine before the electric motor is spins too fast.
Not that it really makes any difference.
desura
4,627
129
101
I mean, is it possible to "downgrade" it to the same battery as a std c-max, instead of replacing the entire thing, when it finally dies.
After having actually been in a Volt, the amount of cabin space taken up by the battery is too much. Same for the C-Max Energi
Yuriman
5,530
141
I highly doubt it.
