Did you buy the processor yet? If not, just get the retail version. It comes with a heatsink and fan which should be enough to keep your system running stable (yes, it uses a pad and not thermal grease (i.e. ASII).
I agree with the others, however, if you have the CPU already either the Cooler Master's DP5-6I31A CPU Heat Sink and Fan Here or the Vantec Socket A Cooler Here are inexpensive and will perform well for your usage.
