Best HSF for 2000+ XP/MP
Fiera
166
What is the best HSF unit for a pair of XP/MP 2000+ on a A7M266D? I'm looking for quiet.
Right now I'm looking at the Thermaltake Volcano 9 SMART & SILENT
Fiera
Nardman
26
check this HSF out http://www.svcompucycle.com/arcoolsupsil.html
I picked one up for my XP 2100 pal and I'm ecstatic with the results. this sucka is cheap, safe and easy to mount, and unbelievably quiet. The only drawbacks that I've found with it is that the HSF is frikkin HUGE (bigger than the 8045) so make sure you have the real estate, and also that it's only adequate with proc cooling. it works great for stock proc speeds, but it's definately not meant for overclocking. Hope this helps you out...peace
akahai
1,230
I have the same mobo with 2 Duron paired with 2 Volcano 7 HSF....the setup works fine. However, due to the limited space around the cpu socket, I have to shaped down couple sides of the HSF in order to fit it on, this might be something you want to consider before purchasing any HSF, as far as I can remember, the space around the cpu socket will not fit most of the bigger(i.e 80mm)HSF...just my $.02..........
