Best HS/Fan for 1.8A P4....noise and cost aren't issues.
HybridX
Hi guys,
I'm new here, but had some questions about cooling. I was a die-hard intel buff for a while, switched to AMD, and now I'm back over to the intel side. Anyways, I've been trying to find some nice HS/Fan combos for the P4, but was unable to find any real input from people. That said, I'm looking for something that is effective. Like the title says, noise and cost are not an issue if it means that my CPU will be cool. Thanks in advance.
blade
1957 - 2008<br>Elite Moderator Emeritus<br>Troll H
Most AMD guys prefer the AX-7, and now there is an AX-7 for the p4. See here
Just add a fan which puts out 35cfm or more and your set. Of course more cfm the better it'll cool but then sound will become an issue.
Another very good solution is the Volcano 7+. It fits either and AMD setup or a P4 with the included adapter. Comes with a 3-speed controlled fan.
Jhhnn
IN MEMORIAM
Nov 11, 1999
62,365
14,684
Or this one, arguable the best-
Alpha
They can sometimes be found a little cheaper elsewhere, but I've always done well with 2cooltek.
zzzz
5,498
There is the swiftech P4 hSF. I think it is priced at about $65.
