slk800 with a smart fan II or a YS TECH adjustable fan
Originally posted by: shikhan
I just got a slk-900(u) for 45 and my god i love it! I'm at 38-45 constant using a panaflow 80mm ( i'm having troubles figuring out how to load the 92mm) its soo quiet. Its well worth it!
[edit] I was just browsing svc.com and slk-800 is under 40 there right now, both versions of it. Go for it!
Originally posted by: rajkanneganti
AX-7 with a Delta or YS-Tech
Yanno I was going to get the all copper by instead got the hybrid AICu. All the reviews I read reported lower temperatures on the hybrid. That with lighter weight and slightly lower cost made the descision easy. I don't understand why the hybrid cools better though. It makes no sense. Copper is a much better heat conducter then alum. The Hybrid is copper center fins and contact point and alum outer fins.Originally posted by: MangoTBG
The Zalman 7000 all copper has my vote! I'm sub 50's at ALL times and I have a 2.4c P4 @ 1GHz FSB and 3.0GHz...looks badass too![]()
pic
pic
I'm no metallurgist.. but for all I know.. copper conducts heat better from metal to metal, but aluminium dissipates heat (to the air) better than copper..
therefore.. if you have aluminium fins surrounding a copper core, you'll get better heat conduction from the CPU core to the heatsink copper core, and the aluminium fins would dissipate the heat to the surrounding air..at least in theory
But we all know that the best heatsinks in the market now are copper (SLK800/900 anyone?)..so the material is not the only thing affecting cooling efficiency..the design plays a darn important role too..
of course that's IMHO.
edit: gah typos i hate u
Originally posted by: JokerF15
Hello Guys,
Take a serious look @ the Coolermaster Aero 7+. Can be found for ~35-37 dollars + ship from most online stores. In my own bench testing, It was very similar to the Thermalright SLK-900 + a 52cfm fan. However this was when the Aero7+ (under full setting) is pushing out ~27cfm. It is very quiet, and very reliable =).
Nice review here: http://www.systemcooling.com/modules.php?name=News&file=article&sid=667
Good Luck with your search.
-JokerF15
yanno I can't find those reviews now. I know they were some OC web sites I had ben to before but I can't recall atm. Now the only comparative review I find says Cu is better then ALCu.... which angers meOriginally posted by: MangoTBG
pic
Could you post some links to these reviews? I read multiple reviews that put the all copper on top. Either way, they are both great coolers, but I'd like to read that. Thanks!
