Best high end power supply for $200 ??
Mfusick
Someone recommend me a power supply that is 850watts+
No more than $200
I want it to be slick and have excellent cable management.
I will go in an Ultra Tower Cosmos II case.
The case is very large and I will run 10 hdd's. I need to be able to accommodate this.
Yep any seasonic would be great or go for a Enermax or Kingwin if you are looking for the Platinum 80+ to help save on your power bill..
Also any Higher end Corsair PSU's are good as well.
Well, there's no "best PSU". Each unit has it's strong points and drawbacks. Anyway, you can get a PowerBird 900, which is an excellent unit that gets 10/35mV ripple (upper limits are 120/50mV) after getting roasted for 9 hours in the hot box...
http://enthusiast.hardocp.com/article/2008/10/07/topower_powerbird_series_power_supplies/8
http://www.newegg.com/Product/Produc...TabStoreType=1
or if you want more, you can get a Strider 1200. It's the same unit as the BFG LS1200.
http://www.newegg.com/Product/Produc...82E16817256041
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story5&reid=162
^ That one's a great deal after the MIR.
Strider is a good deal, 1200w @ $194 = nice. However it only got an 8 @ JonnyGuru
That review is honestly opinionated, he took down the whole score just because it shutdown in the hot box while pulling 1200W. The Real Power Pro and the LS1000/1200 are based on the exact same design, both of which are (if you want to ensure by score) suggested (by JGuru himself) at 9.
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story3&reid=52
It's a better unit than the OCZ ZX. It has a MOV to filter it's output against surges, with Japanese caps on the primary and a stronger build as a whole. It's made by Enhance, who also makes the Strider 1500. The ZX is made by a Chinese company called Great Wall. It's also a solid unit but that platform just doesn't have it all.
Not at all, the SeaSonic Platinum 1000 just got outdone by the Kingwin LZP-1000.
http://enthusiast.hardocp.com/article/2012/01/04/kingwin_lzp1000_1000w_power_supply_review/9
The LZP has lower ripple (30mV's against 60's of SeaSonic), better transient response and is cheaper. All the hype on SeaSonic's is for their rock solid regulation only.
Plus, the Zero-Phase Shift topology used in Platinum SeaSonic's cost twice as much to make as traditional double-forward primaries. The clamps, coils etc. used in them make those expensive.
did not get that from reading the artical..
"This evolution is such that, while this unit doesn't always match the Seasonic Platinum-1000 across the board, it does represent a legitimate challenge to the best power supply we have ever reviewed."
I get its maybe a tie and maybe a fluke good unit.. It is $50 less though but Seasonic is made in the USA and I have to by USA when I can..
Seasonic is NOT made in the USA.
Seasonic and Kingwin are both great choices. I've used Kingwins in recent builds for people after years of Seasonic... no issues at all.
