Best Heatsink for an T-bird 800mhz?
There are a bunch of good ones, but the best bang for the buck goes to the copper bottom Taisol 760. With the stock fan it should keep your T'bird cool, if your thinking of overclocking opt for the black label Delta fan.
If you're value conscious, the Volcano 2 will be more than enough for an 800Mhz Tbird but beware of its stiff clip.
